What have you done with your Mustang today?
ba1rd
Been thanked: 2 times
Re: What have you done with your Mustang today?
Postby ba1rd » Tue Aug 15, 2017 2:20 pm
Manders Mustang wrote:Just make sure the battery is fully unplugged and no chance!
Thanks, yea thats the plan - still one of the vids I watched said make sure no-one is in the driver seat when you connect the battery up again....just incase!
EmilyJoness
Postby EmilyJoness » Wed Aug 16, 2017 11:52 am
my new baby :D :D :rock :rock
Pink Ford Keychain
Has thanked: 530 times
Postby badhand » Wed Aug 16, 2017 3:05 pm
You beat TT for 'Stang Tat with that. It's horrible :lol:
Postby Manders Mustang » Thu Aug 17, 2017 10:34 pm
badhand wrote:You beat TT for 'Stang Tat with that. It's horrible :lol:
At least she's a lass with a pink keychain, TT just has it 'cuz.... :lol: :lol:
ba1rd
Postby ba1rd » Sat Aug 26, 2017 1:12 pm
Just installed the GT350R steering wheel, feels (and looks) so much better!
Postby badhand » Mon Sep 04, 2017 4:16 pm
Not today, but the other day....
Pulled the stripes (and some paint) off it.
Has thanked: 46 times
Postby slowhand99 » Thu Sep 07, 2017 7:52 am
badhand wrote:Not today, but the other day....
Nah.
Needs stripes :lol:
Postby slowhand99 » Sun Sep 10, 2017 11:55 am
badhand wrote:
.............is that a Moaners badge I see? :o
(I typed M O C G B honest TT!)
Postby Manders Mustang » Mon Sep 11, 2017 8:56 am
Knowing BH it probably has "I'm not" a.... Sticker on it :lol: :lol:
In other news - Not quite today, but Sunday. I set a new Personal Best for removing the bumper on the car.... 13minutes flat.
I also removed my old splitter with the lacquer damage and fitted a new one. I've also removed my headlights and Fortis drove from London up to mine to collect them and convert them from a test batch, to a full final customer set.
Postby badhand » Thu Sep 14, 2017 7:31 pm
slowhand99 wrote:.............is that a Moaners badge I see? :o
It was on there from the previous owner. I might have modified it a bit... :D
Postby Manders Mustang » Thu Oct 12, 2017 1:45 pm
Done a shedload since my last post on here:
Painted someones engine covers ruby red and black
got a new order for engine covers in red, black and chrome... so going to work on them tonight
on my car:
Added intercooler
boost leaked my IC charge pipes
Fixed that
Boost leaked it again
fixed that again
now all good
Added downpipe and WGA (With higher pressure spring) - about 10psi vs 4/5psi with 3mm of preload.
Downpipe was a pig, didn't fit the car, the cat rubbed the steering column, MIJ in Walsall fixed this by realigning it and cutting pipes and shiz.
Now datalogging the new tune on it. to refine it.
Added black metal mustang valve caps.
Going to update sync to v 3.10 from 3,08 soon as well.
Postby Manders Mustang » Thu Oct 12, 2017 7:16 pm
Here's some pics of my work (and some spiel to go with them)
Okay here's the downpipe as promised, and WGA and my valve caps.
Downpipe before, cat rubbing against the steering column
Cat and flex pipe after modding to fit:
Welded new bend
Moved the hangar over majorly, welded to the mount point, as i didn't want to fuck the oem fitment too much lol.
Cat and steering column, a lot of space now (the cat sits above and about 13mm to the LEFT OF THE STEERING COL NOW)
Wastegate installed
Valve caps
Thanks again Pumabuild & MustangMustHaves & MIJ performance!
INTERCOOLER
Comparing new vs stock shit
TINTED HEADLIGHTS:
New tune+ tune (well this is the IC version, it's now got a WGA/IC/DP version)
Comparing CAT vs Ambient temp: 17.89 ambient vs 57.1 charge temp. Difference of about 40 celcius. (STOCK IC)
ETS ic:
Ambient temp - 11c vs Charge temp 18.9c. Difference of 8c
Also added indicator fins
and a clean shot...
And painting another set of engine covers
Postby badhand » Thu Oct 12, 2017 8:58 pm
Been busy boy. :rock
Postby Manders Mustang » Thu Oct 12, 2017 9:03 pm
badhand wrote:Been busy boy. :rock
Well someone has to keep me out of trouble!!! :rock
Postby Manders Mustang » Mon Nov 06, 2017 10:53 pm
Dyno'd... Set the turbo alight...
call me TurGLOW powered.
Now the info on dyno:
Info
Dyno: Maha 2 Dyno, 4wd, running obviously on the rear rollers, two contact points.
Day: Dyno Day with overclockers UK, was third car to run.
Mods to engine: Denso itv22 plugs, ETS intercooler, Air Raid Intake Tube, Velossa Tech Ram Air Intake, K&N Panel filter, Tune+ Wastegate Actuator, Cobb Downpipe with High Flow cat (re-engineered to fit a RHD), Magnaflow Competition Cat Back, @Tune+ Tuned (Revised and set in stone)
Mods to mechanical shiz: Pedders XA Coilovers, Steeda Billet IRS inserts and poly inserts, Michelin Pilot Super Sport rear wheels, Rotiform R122 SPF Alloys (Lighter than stock), Mishimoto catch can. (PCV still in, not gutted, no check valve)
Fuel: Tesco Momentum 99 (Filled up to full tank before)
Tyre pressures; 32 on rears.
Figures info:
1) Ignore the wheel horse power, it's way off, the maha dyno doesn't calculate wheel accurately, if you want that I'm gonna have to sit on a hub dyno. as the wheels have 2 contacts point side it's got more resistance.
2) Engine horse power is correct, it's logged V8s at list BHP (410-415 on 5 different V8s). EB lands around 270-280 on clock. so i'm +80/90ish.
3) I don't have a pre mod comparison because I'm stupid, but i'll find an unmodded EB and ask if they can run it to get a brief comparison, last time I went I'd already done a few mods so wouldn't have been fair.
4) It sat at 100mph to warm upm then failed 4 dyno runs due to the car shutting off, as ESC wasn't off, figures on graph are after the third run. Car peaked each run over 170mph
5) yes my turbo and downpipe went red hot
Numbers:
_____Run 1__ - ____run 2_____ - _____run 3___
355bhp/396lbft - 351bhp/392lbft - 356bhp/391lbft
Final log (Graphed):
Corrected engine bhp: 356.9bhp/266.1 KW
Engine Power: 348.2bhp/259.7kw
Wheel power (as above, ignore it): 275.4/205.4kw
Drag power: 72.8bhp/54.3kw
Max power at: 5825/134.3mph
toque: 391.2lbf.ft
Max torque at: 3805rpm / 87.6mph
Max attained RPM: 7445rpm / 171.6mph
Ambient Temp: 17.1c
Intake air temp 20.2c
Relative humidity: 61.5%
Air pressure: 988.8hPa
Steam pressure 12.0 hPa
Rotating total mass: 683.4lb
Rotating test stand mass: 551.2lb
Rotating Vehicle mass: 132.3lb
Users browsing this forum: Twin Turbo and 16 guests
