Recommendations for differential rebuild specialists
Axel F
Postby Axel F » Fri Nov 24, 2017 12:07 pm
Can anyone recommend any companies they may have used for differential rebuild/servicing? My '06 has had a very slight weep for sometime now coming from where the driveshaft attaches to the differential housing, so guess the seals were on there way out!
Many thanks,
Daryl.
Re: Recommendations for differential rebuild specialists
Postby cati » Sat Nov 25, 2017 7:14 pm
try the big garage in the middle of beacon hill - down the road from you.... they rebuild everything lambos to nissans
Postby Spanner Monkey » Mon Nov 27, 2017 1:55 am
It sounds like the pinion seal is weeping.
Any good spannerman worth his salt should be able to sort this for you.
Users browsing this forum: No registered users and 6 guests
