Hi, proud new owner of a 65 plate GT.
I've noticed that she tends to tramline heavily on dual carriageways.
I've noticed this tendency in other rear wheel similar cars of this size with a relatively wide track and tyres.
Anyone else notice this before I get the alignment checked.
It's a kind of side to side 'shoogling'
Tramlining
- badhand
- Site Admin
- Name: Nick
- Year Of Mustang: 1969
- Has thanked: 509 times
- Been thanked: 301 times
- Contact:
Re: Tramlining
Did it on my old '05.
Do the same stretch of road you noticed it on. If it does it there again you've saved yourself a lot of arsing about.
- blahblahdave
- Name: David
- Year Of Mustang: 2009
- Has thanked: 7 times
- Been thanked: 11 times
Re: Tramlining
Does it on my '09 along the same stretch of roads. Fine on others.
I'd definitely blame it on the state of the roads!
- Name: Smogz
- Year Of Mustang: 2015
- Been thanked: 1 time
Re: Tramlining
badhand wrote:Did it on my old '05.
It does it on the same stretch of road as the CLS but in a much more exaggerated fashion.
Feels similar to being buffeted by side winds, isn't restricted to one or two stretches is happening on most A roads.
- Name: Bill
- Year Of Mustang: 2016
- Has thanked: 112 times
- Been thanked: 42 times
Re: Tramlining
Just a long shot before you explore the possibilities. Do you know anybody nearby with an S550. He/she may be willing to run their car down the same stretch of road(s) as a comparison
- badhand
- Site Admin
- Name: Nick
- Contact:
Re: Tramlining
Smogz wrote:Feels similar to being buffeted by side winds, isn't restricted to one or two stretches is happening on most A roads.
Sounds worse than I'd expect, but I know what it's like when you 'think' there's something wrong with your car - you're constantly on the look out for the problem and small issues are magnified in your mind.
I assume you've not modded the suspension and altered camber or toe?
What's your tyre pressures? If they're too high over recommended, that can cause worse tramlining. Check that before marching back to the dealer maybe.
- Name: Ben
- Has thanked: 40 times
- Been thanked: 50 times
Re: Tramlining
Is it both nearside and outside lanes? HGV grooves can play havoc and they're not always obvious.
- Name: Smogz
Re: Tramlining
badhand wrote:Smogz wrote:Feels similar to being buffeted by side winds, isn't restricted to one or two stretches is happening on most A roads.
Yep, probably just me fixating on it. Wondered if it was just a 'thing'.
No modifications, only had her a week
Tyre pressures is a good point, checked them as soon as I got home and they' cooled. All spot on.
I reckon its just tramlining in the road grooves, just a bit disconcerting at times and more apparent than in previous cars.
- Name: Smogz
Re: Tramlining
Finally got it resolved, rear suspension replaced under warranty.
One of the shocks appeared to be mismatched.
