Common Service Items
benny.c
Year Of Mustang: 1971
Postby benny.c » Tue Jan 20, 2009 2:20 pm
SERVICE ITEMS BASED ON '05 GT (V8) MODEL
I'm going to compile a list of common service items. This will reference the Ford part and alternatives that people have found. I'll do the V8 stuff, if anyone wants to supply me with V6 and GT500 info then great.
It would be useful if you could let me have part numbers and suppliers, not just say "yeah a Mondeo filter will fit" ;)
ozza
Re: Common Service Items
Postby ozza » Fri Jan 23, 2009 8:30 am
Done!
benny.c
Postby benny.c » Fri Jan 23, 2009 9:40 am
hertfordtyres
Name: Gill + Dave
Year Of Mustang: 1966
Postby hertfordtyres » Sat Jan 24, 2009 7:07 pm
the v6 uses the same oil filter, fuel filter and air filter
comma make an oil for fords called xtec which is 5w30, which you can buy for as little as £10 a gallon, we (hte) offer this and the vauxhall 5w30 long life oil to mussy owners ( my opinion is if an oil is disigned to do 30k then its going to give better protection for our 5k oil changes) and it doesnt cost that much more
weve found a uk air filter will get the number and put it here
as to the pollen dont take chances like i did, found one just a bit smaller and fitted it and water passed by it and straight on my sjb :(
hence why mine is going in to be recon'd next week :(
as to spark plugs - well ive changed mine at 23k only cost me 35 quid, going to do gills v8 too (numbers to follow)
took some out of an explorer last week with 60k on them....... nasty !!
has anyone managed to come up with a uk conversion on the fuel filter??? not the us fram filter which ive tried to get via fram in the uk?
as to brake fluid dot 3 isnt good enough for our weather. and if your car is 2 years old then it needs changing ive put dot 5.1 in mine and wow !!!!
LV51FER
Postby LV51FER » Sat Jan 24, 2009 8:38 pm
Some oil filter numbers:
K&N Performance Gold - HP-2010
Bosch Premium Oil Filter 3410
Fram PH2
Motorcraft FL820S
AC Delco PF1250
Fuel Filter
WIX 33243
Fram G10166
Motorcraft FG1083
These are $9-$13 from www.rockauto.com - ebay UK want £24.50 for one!
However, I found them here in the UK for under a tenner!(even if I paid $6 for mine in Autozone)
http://www.inlinefilters.co.uk/index.ph ... ord=FG1083
Cabin Filter
Motorcraft FP-53 ($14 from rockauto)
Air filter
FA1773
PCV Valve
EV-273
To be honest, I've had a scout round the web and most are unique to the Mustang and rockauto are cheap enough to get a supply sent over.
D19MON
Postby D19MON » Thu Mar 18, 2010 9:19 am
can anyone tell me about wiper blades? is it just a case of a visit to halfords or is there better ones to be had? :) simple i know but thought i'd ask :oops:
Molehill_Mike
Been thanked: 60 times
Postby Molehill_Mike » Thu Mar 18, 2010 11:24 am
I brought mine from Tesco! Flat blade ones :)
MIke
D19MON
Postby D19MON » Thu Mar 18, 2010 6:13 pm
:D thanks Mike
Expat
Postby Expat » Mon Aug 08, 2011 6:01 pm
Straight from my GT500 owners manual supplement...
5.4L DOHC Supercharged V8 engine
MOTORCRAFT PART NUMBERS
Air filter element FA-1896
Fuel filter FG-1083
Battery BXT-40-R
Oil filter FL-820S
Spark plugs AGSF-22FM1
Brake fluid WSS-M6C62-A or WSS-M6C65-A1
Engine oil (w/ filter change) 6.5 quarts (6.1L) 5W-50 Full Synthetic X0-5W50-QGT / WSS-M2C931-B
Engine coolant - 21.1 quarts (20.0L) VC-3-B / WSS-M97B44-D
Intercooler Coolant - 4.17 quarts (3.95L) same as engine coolant
Rear axle lubricant - 4.25 pints (2.0L) 75W-140 Full Synthetic XY-75W140-QL / WSL-M2C192–A
Rear axle fluid friction modifier - 4 oz. (118 ml) XL-3 / EST-M2C118-A
Fuel tank - 16.0 gallons (60.5L) 93 Octane [(R+M)/2] MINIMUM
Transmission fluid - 6.35 pints (3.5L) Motorcraft MERCON V ATF XT-5-QM / MERCON V
Windshield washer fluid - 4.0 quarts (3.8L) ZC-32-A / WSB-M8B16–A2
From the 2011 Owners manual: (only different part numbers listed - if it's not below = same as GT500)
Component - 3.7L V6 and 5.0L V8 engines
Air filter element - FA-1897
Battery - BXT-96R-500
Oil filter - FL-500-S
Automatic transmission fluid - 11.9 quarts (11.2L) MERCON LV ATF / XT-10-QLV
Manual transmission fluid - Motorcraft Dual Clutch Transmission Fluid XT-11-QDC / WSD -M2C200-C
EDIT: Also have the 2011 Mustang Owners Manual in .pdf form -- too big to attach
Users browsing this forum: No registered users and 5 guests
