Mustang Bulbs - Full list for reference
Be as specific as possible, include as much information as possible and be patient for advice. Someone will be along soon with the answer...
Robbed666
Postby Robbed666 » Sat Aug 09, 2008 3:24 pm
X post from Moaners. Thought it might be of use here as well
Listed below are bulbs fitted to a 2005 Mustang (2006 same IIRCC)
This link is great for finding bulb X references as well (just input the numbers into the top search box)
http://www.donsbulbs.com/cgi-bin/r/t.pl
Of course if the SVA conversion has changed the light units, or aftermarket light units have been fitted, then different bulbs might be required) ;)
2005 Ford Mustang Light Bulb Size Guide
High & Low Beam Headlamp Light Bulb Size:
H13 (9008)
Parking Light Bulb Size:
3157LL
Front Turn Signal Light Bulb Size:
3157LL
Rear Turn Signal Light Bulb Size:
4057LL
Tail Light Bulb Size:
4057LL
Stop Light Bulb Size:
4057LL
High Mount Stop Light Bulb Size:
921
Fog/Driving Light Bulb Size:
9145
License Plate Light Bulb Size:
168
Back Up Light Bulb Size:
921
Rear Sidemarker Light Bulb Size:
2825
Molehill_Mike
Has thanked: 46 times
Been thanked: 60 times
Re: Mustang Bulbs - Full list for reference
Postby Molehill_Mike » Tue Mar 01, 2011 11:09 am
Hi Rob,
Any idea on the map reading bulbs? I am thinking of changing mine to red :)
EDIT
Map Light Bulb Size: 2825 (501)
Good site - http://www.modifiedlife.com/car-replace ... ze-guides/
shmustang
Been thanked: 23 times
Postby shmustang » Sun Jan 03, 2016 2:31 pm
you can now get all the lamps for the mustang in led far brighter and last longer just remember to get the canbus compliant.
this is the site i got all my lamps from
http://www.autobulbsdirect.co.uk/
Return to “Technical”
