Tyres/Alloys
Jayfm
Tyres/Alloys
Postby Jayfm » Sat Jan 21, 2017 5:22 pm
Hi,
I test drove a mustang a little while back and the traction didn't impress me one bit, I got feedback at the time and it was mainly due to the stock tyres. I know I can upgrade to the Michelin pilots but really want to go up a size as well, this would meaning changing the alloys, can anyone recommended where I can get the alloys and tyres and what size is the next step up from stock ? Maybe someone has increased size and could tell me the alloy/tyre sizes I need to look for, and of course what difference overall it made.
Regards,
Jamie
himleiwolf
Been thanked: 26 times
Re: Tyres/Alloys
Postby himleiwolf » Sat Jan 21, 2017 5:59 pm
Jayfm wrote:Hi,
Regards,
Jamie
Hi,
The stock tyres are pretty poor under 7 degrees and in the wet or winter conditions but I have recently changed mine to a set of Pirelli Winters (Sottozero) and the difference is like chalk and cheese. The car now handles well and you can drive with confidence although you would obviously not push too hard
Jayfm
Re: Tyres/Alloys
Postby Jayfm » Sat Jan 21, 2017 9:21 pm
What I can't understand is the is the Pirelli stock tyres get great reviews from numerous sites, the MPS come out a little better but not by much, I guess this makes a difference or maybe I should consider winter tyres all year round... what's the difference between the winter designed tyre and the summer, is it purely down to a better grip on wet/cold conditions ? if so living in britain we might as well just run the winter tyre all year round.
Re: Tyres/Alloys
Postby cati » Sun Jan 22, 2017 12:27 am
Mpss are a million miles better than the stock pirelli.... i think you might be confusing other Pirelli sport tyres with what passes as stock
Number one recommendation is to bin the stock tyres they are only fit for burnouts
If you cant stretch to mpss then go for Toyo - great tyres
Bluestang
Has thanked: 112 times
Been thanked: 42 times
Re: Tyres/Alloys
Postby Bluestang » Sun Jan 22, 2017 12:32 pm
I selected wet/snow mode the other day in greasy conditions and it certainly made quite a difference although as mooted the Pirellis don't seem the best unfortunately.
himleiwolf
Re: Tyres/Alloys
Postby himleiwolf » Sun Jan 22, 2017 1:52 pm
I recently had a session on a skid pan and spoke to the instructors on the subject of winter tyres. Normal tyres start to loose effectiveness at around 7 degrees as the compound that they are manufactured from starts to loose some of their "stickiness" at low temperatures. Not only do winter tyres have bigger and better tread patterns that are designed to move more water, the compound that they are manufactured from is much softer (due to a higher silica content) and so holds the road more effectively at lower temperatures.
I am told that in parts of Europe it is a legal requirement to run winter tyres although I would guess this in countries where they have particularly harsh winters on a regular basis and I can only speak from my own experience that now I have changed, the car handles really well
It should be pointed out that if you are considering swapping then all advice that I have read states that all 4 tyres should be changed not just the rears and that the summer tyres need to be properly stored.
MusTee
Re: Tyres/Alloys
Postby MusTee » Fri Nov 10, 2017 3:06 am
I've seen some people using Nitto and pair it with another tyre brand. Anyone here who has tried to do the same?
Ant379
Been thanked: 40 times
Re: Tyres/Alloys
Postby Ant379 » Fri Nov 10, 2017 8:46 am
Himleiwolf,
What do you mean summer tyres have to be stored correctly?
Wouldn’t being stacked up in a garage be sufficient ?
I have been thinking of getting winter tyres but to save on keep changing them from the alloys, I would get a fresh set of alloys and store the winters tyres in the garage on their alloys in summer ?!?
Huffy
Year Of Mustang: 2000
Re: Tyres/Alloys
Postby Huffy » Fri Nov 10, 2017 2:04 pm
I have been doing this for a few years now for my BMW - I keep mine on something similar to this https://www.rapidonline.com/Sealey-STR0 ... gJPQPD_BwE
but without the castors. It also came with a dust cover. I generally leave about 20 PSI of air in them and wash and dry them before I store them. You should keep them out of direct sunlight and much the same as storing a car if the wheels aren't off the ground it would pay to turn them every so often.
Re: Tyres/Alloys
Postby TimG » Tue Nov 21, 2017 9:06 am
I have another set of standard alloys with Nokian WR A4 winter tyres fitted, they are excellent giving much more confidence in winter conditions. The tyre supplier used their own TPMS sensors reading the codes off the existing set & calibrating accordingly. Mark with corner when swapping over.
I wash them before storing horizontally off the ground stacked in the dark.
Tim
Users browsing this forum: No registered users and 8 guests
