Detailed Order Process (UK - S550)
Re: Detailed Order Process (UK - S550)
Postby Manders Mustang » Thu Aug 03, 2017 7:09 am
I'm ignoring doing the current My17 order list. It's been sped up so they can clear the order books.
Casej13
Postby Casej13 » Tue Aug 15, 2017 9:00 am
Car has been built for nearly four weeks now and still hasn't appeared to have left Flat Rock.
Ford UK told me they've emailed the plant last week but I've heard nothing since.
I imagine definitely looking at October now if not November :-(
Postby Manders Mustang » Tue Aug 15, 2017 10:59 am
Casej13 wrote:Car has been built for nearly four weeks now and still hasn't appeared to have left Flat Rock.
U got a VIN?
Casej13
Postby Casej13 » Tue Aug 15, 2017 11:12 am
Yes - the window sticker shows it as built on the 19th July but it hasn't updated from "Awaiting Shipment" on Cotus since then...
Lemonsausage
Year Of Mustang: None
Has thanked: 3 times
Postby Lemonsausage » Tue Aug 15, 2017 11:43 am
Casej13 wrote:Yes - the window sticker shows it as built on the 19th July but it hasn't updated from "Awaiting Shipment" on Cotus since then...
Have you tried using your VIN in this form? (plonk it in cargo id)
https://www.2wglobal.com/webapps?frameI ... SearchPage
Casej13
Postby Casej13 » Tue Aug 15, 2017 11:45 am
Yes mate - it just says no record...
Postby TimG » Sat Aug 26, 2017 2:08 pm
I've just had a look at the Window Sticker on Research Maniacs & it does not completely tally. I dont have Sirius radio (US only) nor Sync 3 only Sync 2. Where is the universal garage door opener to be found, on the key, if so not mine? The car does not have hood vents ( not european spec) , nor sequential turn signals & I dont think the fog lamps are LED. The optional equipment/other list does seem correct.
On the FordEtis summary I'm unable to expand the minor features list.
Postby Manders Mustang » Mon Sep 04, 2017 9:22 am
TimG wrote:I've just had a look at the Window Sticker on Research Maniacs & it does not completely tally. I dont have Sirius radio (US only) nor Sync 3 only Sync 2. Where is the universal garage door opener to be found, on the key, if so not mine? The car does not have hood vents ( not european spec) , nor sequential turn signals & I dont think the fog lamps are LED. The optional equipment/other list does seem correct.
That's common, window sticker isn't valid for export models unfortunately, but it's still the window sticker that comes with the car, this is due to differences in export models :)
Postby slowhand99 » Thu Sep 07, 2017 8:00 am
TimG wrote:On the FordEtis summary I'm unable to expand the minor features list.
Looks like Ford have 'improved' the Etis site, and now it doesn't work :roll: . Mine used to work, but the site looked different then. Keep trying, hopefully they'll fix it.
Lt Bullitt
Postby Lt Bullitt » Tue Feb 20, 2018 7:58 pm
Just had a build slot come and go ( lapsed I`m told ) looks like Ford are as organised with the Mustang builds now as they were in 1964, from what I can gather the phrase headless chickens rings a bell
Postby Manders Mustang » Tue Feb 20, 2018 10:07 pm
Lt Bullitt wrote:Just had a build slot come and go ( lapsed I`m told ) looks like Ford are as organised with the Mustang builds now as they were in 1964, from what I can gather the phrase headless chickens rings a bell
headless chickens would at least be "Predictable" :lol:
Lt Bullitt
Postby Lt Bullitt » Mon Apr 09, 2018 9:20 pm
Yes that`s true - anyways I`ve just got my next build slot through, which is the 11th of June so fingers crossed for that one, don`t know why but I had a feeling that the soft tops would carry a delay till they churned a good amount of face-lift model hard tops out first
Oh well hopefully mine will be at the dealership with some decent weather still here ( August maybe ) if all goes to plan, but something tells me Sept
Postby Manders Mustang » Tue Apr 10, 2018 2:34 pm
Lt Bullitt wrote:Yes that`s true - anyways I`ve just got my next build slot through, which is the 11th of June so fingers crossed for that one, don`t know why but I had a feeling that the soft tops would carry a delay till they churned a good amount of face-lift model hard tops out first
They've been pushing a lot of orders backwards, some are rightly so (Rear wing), others are because ford are heavily limiting production of these in RHD models to try and shift the MY17s on forecourts.
Users browsing this forum: No registered users and 12 guests
