MFUK Project car 'Hellraiser' - The build thread.
Like it says, the area to discuss general topics which are not related to other forums.
Has thanked: 501 times
Been thanked: 301 times
Re: MFUK Project car 'Hellraiser' - The build thread.
Postby badhand » Sat Mar 10, 2018 12:30 pm
Following on from comments made on Facebook, where Robbie from Steeda UK reckoned that over arches were passé :lol: I bodged up a quick visual of an alternative to consider. Bear in mind that the top image with bolt on arches is what we were thinking at the start of the project, when we had the renders done. Latest thinking is to fab out of steel and blend in nicely. But before we do, it's worth exploring options innit?
Been thanked: 335 times
Postby Manders Mustang » Sun Mar 11, 2018 11:23 am
badhand wrote:
Blend these, no xxxx ricer riv nuts. sorted.
Postby badhand » Thu Mar 15, 2018 1:01 pm
Got the samples from Forgeline. Beautiful finish. Photo does no justice...
Postby Manders Mustang » Thu Mar 15, 2018 10:36 pm
badhand wrote:Image
i like the top one :lol:
Postby badhand » Fri Apr 13, 2018 1:29 pm
Well, race season is apparently over on Monkey Island, so the drag-ape has stopped dragging his knuckles from strip to strip and has got his hacksaw out at last. Keeping his plans top secret as always but here's a teaser from his Polaroid camera: Upper & lower mount brackets for the front-front wishbone mounts. Holes are 12mm. Square cut out wraps around the chassis. Top mount furthest out, bottom mount low & in.
Postby badhand » Mon Apr 16, 2018 4:49 pm
Scribblings from the Ape's maths book. Plans for the front suspension showing camber-up on bump. From droop to bump in this plan is around 110mm (the standard 4" for this kind of thing) And if you look at the hub, you'll see it goes from parallel (will actually be a couple of degrees in) to 5 degrees at full bump. Ergo, the difference between the wheel at droop vs bump will always be 5 degrees+
Postby badhand » Tue Apr 17, 2018 10:25 pm
More news from nowhere.
Elusive oversize Antipodean weld-in rosejoint slugs arrived today!
Sorry. Shit post. But I'm excited something is a-happening.
Return to “General Discussion”
Users browsing this forum: No registered users and 9 guests
