MFUK Project car 'Hellraiser' - The build thread.
Re: MFUK Project car 'Hellraiser' - The build thread.
Postby cati » Thu Feb 08, 2018 2:50 pm
badhand wrote:I've mentioned way back that one of my/our problems is the gearbox. We have the spanking new Tremec, but whilst that's fine for Nic, I have a disability which makes manual changes a bit of a pain.
there are a few that would argue that i can't change gear properly.
Has thanked: 526 times
Been thanked: 305 times
Postby badhand » Tue Feb 13, 2018 7:35 pm
Some news at last from Spanner Monkey Island!
Looks like the idle beast has got off his big blue arse and started fiddling with metal instead of his balls... It's 3mm mild steel with an anti-corrosion coating apparently.
Anyway, the 4 shapes on this chunk are the front mounts for top and bottom wishbones. These will sit around the chassis box and be welded to it. Top mount is level with the outside of the chassis box, bottom mount level with the inside.
Monkey boy reckons he's been a bit radical with the anti-dive so the bottom wishbone front mount is 100mm down from the underside of the chassis.This apparently angles the lower wishbone down at the front so that under heavy braking the 'bone is not acting parallel to the chassis, thereby reducing the load that the suspension receives. This could also be done by angling the top wishbone backwards, but my hairy friend never felt that was very efficient.
The other shapes are the balljoint mount plates. these will have reinforcement gussets around them. The lower mounts will be tied in to the coil-over bottom mount.
Postby badhand » Sat Feb 24, 2018 8:15 am
Come on Spanner Monkey!
Postby badhand » Wed Feb 28, 2018 9:20 am
I'm obsessive about colour, so rather than rely on web photos for accuracy, I'm getting samples of the actual finishes sent over from Forgeline to compare against our Comp Orange Calipers etc. in the flesh. Already, the photos of the wheels and the photos of the samples look quite different. But it's awesome that Forgeline will do this.
Probably end up going for a bad ass black combo anyway...
Postby Manders Mustang » Wed Feb 28, 2018 11:27 am
badhand wrote:I'm obsessive about colour, so rather than rely on web photos for accuracy, I'm getting samples of the actual finishes sent over from Forgeline to compare against our Comp Orange Calipers etc. in the flesh. Already, the photos of the wheels and the photos of the samples look quite different. But it's awesome that Forgeline will do this.
(if they're numbered 1,2,3,4 with 1 being the greenish grey, 2 being grey, 3 being blueish grey and 4 being creamish grey)
I like #2. :lol:
Postby badhand » Wed Feb 28, 2018 12:59 pm
That's why I need to see in the flesh rather than onscreen. None of them are grey.
You like Matte Bronze.
Postby Manders Mustang » Wed Feb 28, 2018 2:40 pm
badhand wrote:That's why I need to see in the flesh rather than onscreen. None of them are grey.
What fking camera do you have, jesus Christ these all look so different.
Postby badhand » Wed Feb 28, 2018 3:50 pm
They're supposed to look different.
What kind of xxxx screen do you have? :lol:
Postby Manders Mustang » Wed Feb 28, 2018 6:41 pm
badhand wrote:They're supposed to look different.
well i was looking on my 720p monitor at work.
then 720 at home
now 4k at home, same shit, all fucking whack left to right is dark grey, blue grey, dark blue grey, yellowy grey
Postby badhand » Wed Feb 28, 2018 7:17 pm
Well calibrate your f@cking eyes then. :lol:
Postby cati » Fri Mar 02, 2018 10:38 pm
they all look the same to me
Postby cati » Fri Mar 02, 2018 10:39 pm
then 720 at home
Manders clearly lives in a 720p world....
Postby Manders Mustang » Sun Mar 04, 2018 8:09 pm
then 720 at home
my work does.
Postby cati » Tue Mar 06, 2018 6:31 pm
and we wonder why there was a banking crisis.........
Postby Manders Mustang » Tue Mar 06, 2018 10:04 pm
cati wrote:and we wonder why there was a banking crisis.........
you think we invest in tech? hahahahahahahhahahahahaha :lol:
Users browsing this forum: No registered users and 4 guests
