SVA - Headlights
Buying from abroad or selling to another country.
nomis
Year Of Mustang: 1971
SVA - Headlights
Postby nomis » Wed Oct 01, 2008 8:13 am
I notice many Mustangs have holes drilled in the headlights, small bulbs/LEDs installed so that the SVA requirement for white side lights is complied with.
Has anyone done a less intrusive (ie no drilling into the headlamps) route to pass this SVA requirement?
ozza
Re: SVA - Headlights
Postby ozza » Wed Oct 01, 2008 8:31 am
nomis wrote:I notice many Mustangs have holes drilled in the headlights, small bulbs/LEDs installed so that the SVA requirement for white side lights is complied with.
Not to my knowledge. Angel Eye is the other option.
Geoff Watts
Year Of Mustang: 1972
Postby Geoff Watts » Wed Oct 01, 2008 8:53 am
Mine has a 5w bulb in the casing in front of the headlight, barely noticeable during the day unless you look for it but very effective at night ;)
Viper
Postby Viper » Wed Oct 01, 2008 6:42 pm
I like the look of Angel Eyes but not available on a GT500 if that's what you're getting. :?
Are your lights xenon?
Has thanked: 876 times
Postby Twin Turbo » Wed Oct 01, 2008 6:56 pm
My sidelights are seperate to the headlights......they're down by the lower air intake, either side of the number plate. Oh and the right side one looks wonky in this picture! However, my SVA could have been done by Bodget and Scarper, for what's it worth :?
nomis
Postby nomis » Thu Oct 02, 2008 10:27 am
Viper wrote:I like the look of Angel Eyes but not available on a GT500 if that's what you're getting. :?
Yep, HIDs
Thanks for the comments guys. :)
SurreyMustang.Com
Postby SurreyMustang.Com » Thu Oct 16, 2008 2:44 pm
Ours are slightly different:
The bulb sits between the black trim and the headlight reflector. Looks a bit neater than a hole bored straight through the casing and trim, and can always be removed to get the lights back to standard.
Works with HID's as well (though not for SVA as has been discussed).
Return to “Import/Export”
