Windows Mobile Hamburger Menu Issue
A place where users can inform Admin of bugs or suggestion to improve the MFUK forum
Postby mattmoxon » Tue May 19, 2015 1:57 pm
I have noticed an issue when using my windows phone to log in and use the hamburger menu that there is a minor display issue. I can still see the Board Index / Mustang Forum UK / etc. Menu and the search. I have attached a couple of screen grabs to illustrate this:
Its not a massive problem, but I thought you should be aware of it.
-Matt M
Molehill_Mike
Been thanked: 60 times
Re: Windows Mobile Hamburger Menu Issue
Postby Molehill_Mike » Tue May 19, 2015 2:10 pm
If you turn the phone sideways do you get the same issue? I must say I've only used my phone to access the ACP, will actually take note of the mobile version later :)
Ta
the stang
Been thanked: 6 times
Postby the stang » Tue May 19, 2015 5:00 pm
Molehill_Mike wrote:If you turn the phone sideways do you get the same issue? I must say I've only used my phone to access the ACP, will actually take note of the mobile version later :)
Ta
Mike,
I also posted this on page 2 of the "we are up and running" thread.
Yes it does the same in landscape. And my mobile screen is a quad HD so higher resolution than a lot of PC's
Steve
Postby mattmoxon » Tue May 19, 2015 5:09 pm
Yep, it does indeed do exactly the same thing in landscape view.
Has thanked: 526 times
Been thanked: 305 times
Postby badhand » Tue May 19, 2015 5:56 pm
I'm aware of it. Working on it. Bit of a Matt job Mike. Leave it to the Doctor!
Postby badhand » Thu May 21, 2015 8:26 pm
Should be fixed. Fine on iPhone, let me know on Android etc....
Postby cati » Thu May 21, 2015 10:00 pm
It is... Well done to the data monkey!
Postby mattmoxon » Wed May 27, 2015 6:49 am
It appears to be fixed, I guess the topic can be closed now.
Return to “Forum Feedback & Bug Reporting”
